How much nitrous w/383 can i run
Old Apr 5, 2005 | 11:41 PM
blitz1029's Avatar
Im currently building a 383 all forged with 11.8 to 1 compression. Also LE3 head and cam package. And the rest of my mods are comp cam pro mag rollers 1.6, comp cam pushrods, comp cam R lifters, delphi 42lb injectors, holly fuel pump, pacesetter LTs, meizere electric water pump, and i think thats it.
How much of a shot of nitrous could i run safely? I was also planning on going with the wet nitrous kit.
Old Apr 6, 2005 | 09:12 AM
LameRandomName's Avatar
Re: How much nitrous w/383 can i run
Keep in mind that as a general rule of thumb, you can add another 50% with nitrous. In other words, if your engine is making 500hp (at the flywheel), without the juice, then you can add another 250hp with it.
Now, 500 + 250 = 750.
So, if your engine parts are rated for 750hp, and you have done the proper block prep, then you should have no trouble. Keep in mind that if you want to make "X" amount of total horsepower while on the bottle, then you have to build the engine as if it were making that much horsepower all the time.
What this means is; your question is better asked of YOU. What parts did you buy? What block prep did you do? How much HP can your engine make before it breaks? If you answer those questions, then you'll know how much you can spray.
Old Apr 6, 2005 | 10:44 AM
GetaZforgetGT's Avatar
Good post LameRandomName.
When I had my motor built the first thing I told them was that this engine is going to get at least a 200 shot on it.
This allows them to select the proper parts and ring gaps to accommodate your needs.
If your ring ends touch....your gonna need a trailer to make it home.
If your building the engine I would just call up your ring manufacture and see what they say about the ring gap required for the shot that you would like to use but as mentioned above all parts must be built to handle the HP that is created by nitrous.
Old Apr 6, 2005 | 10:56 AM
Nitro Dave's Avatar
Actually,
This is one of those post that need more detail.
What pistons?
What rings?
What Rods?
What Crank?
Does the block have splayed caps?
All these things will also go into play.
Dave
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
