how long will a bottle last?
Old May 6, 2003 | 08:50 PM
93transam1234's Avatar
With a 10# bottle. on a mostly stock LT-1. How many 1\4 runs could i make with a 100hp NX system set to spray at WOT and cut off betwen shifts
Old May 8, 2003 | 01:02 PM
hmmm
does anybody here run anything like this????
How much does N2O cost per pound at a speed shop?
Old May 8, 2003 | 02:07 PM
COMNBYU's Avatar
Some people will prolly tell you that you'll get a whole bunch of runs on a 10lb bottle, but I've never got, nor heard of anyone else locally, getting what people on this board get per bottle.
When I had my 100 pills in I could usually get 6-7 FULL 1/4 runs per bottle. Now that I have the 150s, it's normally around 5.
As far as price, most shops charge anywhere from 5 bucks on up per lb. I have a friend who has his own filling station and hooks up people he knows and friends. Technically, he charges 3 dollars a pound, but he usually just takes 30 bucks even if he goes over, which he normally does. He'll stuff about 27-28 lbs in
Jon
Old May 8, 2003 | 09:17 PM
z2894convertible's Avatar
Jon
How can he get that in a 10 pound bottle?
Old May 9, 2003 | 09:06 AM
stik6shift98's Avatar
about ten runs.....
5 dollars and up per pound
around here its 2.75 to 4.50 MAX
Old May 9, 2003 | 10:03 AM
COMNBYU's Avatar
It's a 10 lb bottle, and then it holds another 15 lbs of N2O. A total of 25 lbs When you get your bottle filled, they weigh the total lbs. I didn't mean 26-28 lbs of N2O, sorry...
Jon
Old May 9, 2003 | 01:27 PM
SilentBob's Avatar
Jon
Correct me if I am wrong, but I thought that "10 pound bottle" meant it held 10 pounds or n20.
SB
Old May 9, 2003 | 01:37 PM
COMNBYU's Avatar
SB
Well, all I know is that when I have my bottle filled and weighed, it normally reads 15-17lbs BEFORE it's filled, and 26-28 after.
Maybe it's the bottle that weighs 15lbs??
Anyhoo, that's how it works for me...
Jon
Old May 11, 2003 | 04:41 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Your bottle should have the weight on it when full and empty. empty I think is 15lbs. So add 10 more pounds to that and you get 25lbs total. I think that's what he meant to say.
calaban
May 18, 2020 06:43 PM
Bobczar
Oct 23, 2015 11:22 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
alphaauto
Jan 23, 2015 07:42 AM
