How do you pull timing?
Old Jul 9, 2005 | 03:52 PM
Black1995Z's Avatar
Cool How do you pull timing?
Whats the process of pulling timing and how do you do it?
Old Jul 10, 2005 | 11:10 PM
slowpoke96z28's Avatar
Re: How do you pull timing?
you can use http://www.msdignition.com/ignition_18_6520.htm
i want to get one of these for my LT1 car
Old Jul 10, 2005 | 11:50 PM
pennys58's Avatar
Whatever you do, don't go this way...for I still don't know the answer!
http://web.camaross.com/forums/showthread.php?t=372359
I have the 6al/dig window switch/8982. I lost 20rwhp with 2* of timing. Since I hardly spray, I am contemplating taking the 2* out. And if the digital is the answer, I hate to spend 3 bills when I've already spent over that on the 3 things I've already bought!!!
Old Jul 11, 2005 | 01:09 PM
OBE1 95Z28's Avatar
An aftermarket ignition box with timing retard function lets you pull timing when you run nitrous, yet let's you keep full timing for all other occasions. The ignition boxes also generate a hotter spark which helps to keep the nitrous from "blowing it out".
Old Jul 11, 2005 | 02:01 PM
Black1995Z's Avatar
damn, I just bought an MSD6A not the "6AL"
I was wondering cause im rebuilding and im going to be putting on the timing chain/gears and thought it had something do to with it
Old Jul 11, 2005 | 02:37 PM
2000GTP's Avatar
You could have a second PCM chip burned that has custom timing curves and just swap the chips when you are at the track spraying.
Old Jul 11, 2005 | 02:46 PM
pennys58's Avatar
I was just told that you didn't have to pull timing under a 150 shot...if there weren't any signs of detonation. How can you determine if it is detonating? I've already spent the money on all 3 items and I definately don't want to spend more on the digital box...so I may just pull the timing out. I mean, it's not like I have a 55 gallon drum of nitrous in my back seat that I continuously spray. I just hate the fact that I lost 20rwhp. Good or bad idea??
Old Jul 11, 2005 | 02:57 PM
Alvin@pcmforless.com's Avatar
I've got new chips out that have a wire coming from them.. Ground the wire and you go into a nitrous mode.. or less timing and adjust AFR (if you give me a dyno sheet with the jets your using.)
Old Jul 11, 2005 | 03:14 PM
Black1995Z's Avatar
so you dont need to pull timing for shots 150 and below??!
Old Jul 11, 2005 | 03:44 PM
pennys58's Avatar
I have a dyno tune...will this chip work with that? Does it have a window switch in it? How much is the chip? How does it work??!!!!!!!!!!
Old Jul 11, 2005 | 03:45 PM
pennys58's Avatar
That is what Nitrous Express told me. He said it was okay as long as there wasn't any detonation.
Fatdog2
Feb 13, 2015 08:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Gtpguy
Jan 26, 2015 04:50 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
