How Big Of A Hit Are You Using Through A LT1 Plate System?
Old Jul 15, 2002 | 08:30 PM
Victory Racing's Avatar
Post How Big Of A Hit Are You Using Through A LT1 Plate System?
I plan on making a few test runs soon and wanted to jet the car up a bit. I was running a 200 hit which was no problem, but I want to try and get a 9 second time slip.
I know I am going to need every bit of 250 or 300 to get the car to go that quick. However theren lies a problem.
I have heard of several situations where nitrous and fuel distribution became a problem. Specifically the Nitrous and Fuel fly right past the front two cylinders and they run lean.
Can anybody add any fact to this claim?
Also for what its worth I am using the TNT Twister Plate System. Thanks for any and all replys.
Nick D'Agostino
**FOR SALE**
1997 Silver Camaro SS
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
4L60E Race Built Trans
TNT Twister NO2 System
Best Times To Date
NA Time 12.15@111mph
NO2 Time 10.66@128mph
E-Mail For More Info
1995 Emerald Green Formula
Stock For Now
Times to Come
If you live life by the book, all you get is what has already been written.
I am a Proud Supporter of ......Boycott Lapeer Dragway
Old Jul 15, 2002 | 10:57 PM
kmook's Avatar
Advanced Tech Moderator
Post
I know its not what you wanted to hear, but i only like DP for over a 200-250 shot.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Old Jul 15, 2002 | 11:07 PM
Post
I just wonder if I can make the power at a 250 hit that it will take to get the 9's.
Nick D'Agostino
**FOR SALE**
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Stock For Now
Times to Come
Old Jul 16, 2002 | 03:29 AM
iwon's Avatar
Post
ur nick agostino!! what the hell spray the hell out of it and do a family rebuild :^).
no but in honesty i would be real worried of doing that as u said before there is a point where it goes stright to the back of the intake and either puddles. or u get rich rear pistons and lean front pistons.
i have a buddy down here in South Florida on ths sffba.com his name is Matt he is spraying a solid 200 shot on a stock motor no cam no heads, he hasnt got to run the car because of Turbo 400 problems to large of a stall for a daily driver, but anyways i know he sprays 200-230 on a i believe 97 ls1 T/a and had a compression check and everything was still fine.
so if u have a built motor i would only be real worried if u have high compression but i say go for it atleast once to get a 9sec slip, but im no where near what u are so i guess im just dreaming.
everything just my $.02
-Nick
Old Jul 16, 2002 | 06:32 AM
Post
Well this isn't the first time this has happend but I am not Nick from Agostino Racing Engines.
AREOwner= Nick Agostino
ARE Customer = Nick D'Agostino
I am obviously the later
No problem when my car was there and since it has come home this happens all the time.
I am going to do a leak down and compression check on the motor just to ensure that it is perfect still then the tuning begins.
I need 625rwhp in order toeven stand a chance at getting the 9 second slip.
Nick D'Agostino
**FOR SALE**
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Stock For Now
Times to Come
Old Jul 16, 2002 | 03:39 PM
iwon's Avatar
Post
well i think u should be able to handle atleast 1 pass, btw are u planning on spraying out of the hole? thats where most problems would occur
Old Jul 18, 2002 | 01:56 PM
Trans Am WS6 420's Avatar
Post
Hehe, I guess I'll throw my $.02 in here
I'm only running the shot I am because I am running a progressive controller with it to soften the blow. I'm not a giant fan of slapping the stock internals with a 200+ shot at one time. Thats not to say it can't be done (hell, everyone running a TNT "150" is doing basically that), I just would like to see my motor hold together a bit longer.
FWIW, I have never had any kind of distribution issues that I know of. I wouldn't advise doing what I am, because you may well run into that very problem. But so far, the car purrs like a kitten, and frequent plug checks show that everything looks pretty even.
- Matt
Old Jul 18, 2002 | 02:35 PM
Post
My shortblock is everything but stock. Ross Pistons, Billet Lunati Rods, Lunati 4340 Crank, 4 bolt billet mains, etc, etc.
I have used a 200hit with no problem. I am thinking we will try a 250 hit and see how it works.
Direct port may be in the future though.
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Stock For Now
Times to Come
Old Jul 18, 2002 | 04:12 PM
Post
With all due respect, if you hit that with anything LESS than a 200, you threw your money away on that bottom end.
But DP would be a really good idea.
- Matt
Old Jul 18, 2002 | 05:42 PM
Post
He He I hear ya there, but if I come right out and put 300 through that plate and melt a piston I end up in the same boat
We will have to see how things go. I was just wondering if anybody has hit 250 or 300 through their plate system with any dependability.
Old Jul 19, 2002 | 08:41 AM
SILVERZZ28's Avatar
Post
Cars with a 200+ also requires a chassis that will handle that much shock to the ground. You might want to think of a 2 stage!
Old Jul 19, 2002 | 09:08 AM
Post
The car has full BMR suspension as well as HAL's at all four corners. It also has airbags in back, so the suspension is all set.
For traction out back it has 28x12.50 ET Streets, ao it hooks just fine.
I was just wondering about distribution issues in the intake with a big shot. I will take this to the drag section, maybe better luck there.
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Stock For Now
Times to Come
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
ChrisFrez
Nov 30, 2014 08:41 AM
