Help with Zex kit
Help with Zex kit
Ok I have everything hooked up with a rpm window switch and I am pretty sure that everything is hooked up correctly. The problem is my friend told me that there should be a red light thats on when the box is on. But since the window switch is there it shouldt come on until 3000 - 5600 rpms. So I turned the ignition on to the car, pushed the throtlle all the way down and pushed the button. Then I started the car and pushed the throttle down and at 3 grand the green light flashes. Is it supposed to flash? Also there is not any nitrous that comes out. Any ideas?
Thanks.
Thanks.
A ZEX nitrous kit has to "learn" your TPS signal, If I remember from installing my friends you have to hook it up then a certain color comes on and someone has to be in the car and pushes the accelerator down and up a few times with the key on.
And if I remember right the light on the main ZEX box will change color when it "learns" you TPS signal when you move the accelerator pedal.
Sorry , I asked my friend and he doesn't know where the instructions are at. I will ask him again and see if he can find them, check with www.zex.com and call thier 1-800 number on the website they are really nice and helpfull.
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
