HELP!!! Im confused
HELP!!! Im confused
Ok I have a 2000 Z28 A4 and i just reciently put a NX Wet Kit on it everything worked good and so on well i was out racing a Corvette and after we got done racing i could smell OIL so i got off of the E-Way and pop my hood and i see that the Oil dipstick has came out and there is oil all over the engine (This only happens when I am Spraying) Now i know that the reason that it is doing this is that there is to much crank case pressure but why would it do that ... Rings? (I Hope Not!!)
Re: HELP!!! Im confused
Most likely cracked/broken ring lands.
With your engine idling, remove your oil fill cap and see
if you have the chug-of-death(blowby)coming out of the
valve cover. If so, its time for that rebuilt. Been there, done
that(twice).
Emil Dusek:93Z
that(twice).
Emil Dusek:93Z
Nayr
Mar 3, 2023 08:34 PM
