Help with fuel system
I need some help deciding on a fuel pump. First off my camaro is a track only car. I'm going to be running a carbureted motor that should make ~600HP at the crank and then I'll have a dual stage plate setup running a total of 300HP on top of that. I've sumped the stock fuel tank and will be running an inline electric pump. I'd like to keep the fuel system as simple as possible and just run one pump to feed the motor and nitrous if possible. Do you think an Aeromotive 11203 or A1000 pump would be enough for this? Or should I be looking at something bigger like the A2000?
Jul 4, 2005 05:00 PM
