Fuel pressure safety switch and dry nitrous
Old Apr 12, 2016 | 09:14 PM
CamaroSS30thAnn's Avatar
Hey guys I got a Lt1 motor.
Where do u guys typically mount your FPSS in your fuel system?
Old Apr 13, 2016 | 05:22 PM
Re: Fuel pressure safety switch and dry nitrous
If you are running stock fuel rails, you would use the Schrader valve.
Old Apr 13, 2016 | 05:57 PM
Ah awesome thank you sooo much Injuneer. You are always extremely helpful.
So wiring wise I just need clarification. I have the Mallory 685 box and in the link I post they show in post #10 that the violet wire is used to ground it with that system so I assume it's going to be the same as my settup in post 47 it was with the mallory and zex dry system.
Also I have a nitrous express FPSS what your opinion on that? I hear people have problems with a lot of FPSS. Not specifically NX...
Old Apr 13, 2016 | 05:59 PM
https://www.camaroz28.com/forums/n2o...wiring-536877/
Sorry here's the link
Old Apr 14, 2016 | 05:44 PM
I have no idea what is in the ZEX box.
Running a dry system, if you lose fuel pressure and cut spark, you will lose all power. If you lose fuel pressure and cut the nitrous, you may have enough fuel to keep the engine running and get off to the side of the track or road.
Old Apr 14, 2016 | 06:20 PM
Ok.. thanks I'll keep looking to see how ton hook this up. I appreciate your help
Aug 18, 2015 07:08 AM
gonzo275rltw
Jul 10, 2015 11:47 AM
lildemars09
May 28, 2015 07:54 PM
IROC Z 350
Aug 2, 2002 11:53 AM
CPFarhood
Jun 14, 2002 07:30 AM
