Fuel Leak
Fuel Leak
There is a fuel leak on the blue fitting that attaches to the FPSS. There is a port on the back with a plus that I tightened as hard as I could, yet it still leaks. Any suggestions?
Re: Fuel Leak
I ran into this tonight
just make sure it is actually from the an fitting and not from the male fitting that is welded to the rail. Mine developed a small crack and is spewing fuel everywhere, pretty little weld too so be carefull there.
Re: Fuel Leak
Originally Posted by 94NDTA
I was wondering if I should clean off the fittings or anythign to get a good seal. If so, how would I do that.
Re: Fuel Leak
can you verify that the fuel is coming from the threads? what i would do is take off the line, and replace the schreader valve, then check for leaks. if none, then use a small amount of liquid teflon and replace the line after taking the schrader back out. if there are leaks, find someone to weld the test port on the fuel rail. you will need someone who can weld thin material, like aluminium.
ChrisFrez
Feb 22, 2015 08:47 AM
Alex Barnes
Jan 24, 2015 10:21 PM
