FS: Separate Nitrous fuel system
Figured this might be better posted for more hardcore N2O guys...
Holly Blue Pump w/ regulator
2 Gallon Cell
Fuel Filter
All braided lines and AN fittings up to fuel solenoid
Aluminum panel to mount fuel cell
http://torqueaddicts.com/media/Fuel%20Cell/index.html
The pump/regulator/lines/filter have 2 passes on them, but the tank was used for an air-water intercooler before being dedicated to fuel. All parts are in great shape.
I was going to use this because I didn't want to upgrade my intank pump for the nitrous, and this would have allowed me to run high octane while spraying. Pieced together for a ~225 shot.
350 plus shipping.
Ryan
2 Gallon Cell
Fuel Filter
350 plus shipping.
Ryan
Originally posted by JSK333
Is that area the same as LT1 underhoods? Is your battery in the rear?
Ryan
Originally posted by 96speed
Yes and no. The battery stays up front, on top of this. You will need a coolant overflow/catchcan like the one pictured - 15 bucks. The catchcan may be mounted anywhere. If you don't have A/C it mounts nicely in the dryer's location (as pictured).
Ryan
Ryan
Thanks! Feel free to email if you want.
Solomon, sent you an email
Just FYI, catch can can be mounted anywhere you want - the nice thing about not being off the shelf is that you can design it however you want
I would mount the catch can under the battery area, in the splash guard area if room wasn't abundant.
Ryan
.Just FYI, catch can can be mounted anywhere you want - the nice thing about not being off the shelf is that you can design it however you want
. I would mount the catch can under the battery area, in the splash guard area if room wasn't abundant.
Ryan
Originally posted by 12Second3rdgen
I ran a similar system, I switched to the Quick Fuel technologies regulator and have never been happier. Love having a return
, I was having pressure creep with the holley really bad.
http://web.camaross.com/forums/showt...ghlight=return
Ryan
Jul 4, 2005 05:00 PM
