Finished installing Nitro Daves solenoid bracket
Old May 16, 2007 | 11:29 AM
2000GTP's Avatar
Finally got around to finishing installing the intake solenoid mount bracket from Nitro Dave, here are a few pics, excuse the dirty engine bay :
Old May 16, 2007 | 02:24 PM
Sinister95Z's Avatar
I must say it looks very good! Every time I see these brackets, I get more and more interested.
Old May 16, 2007 | 05:09 PM
ltwonz's Avatar
Looks good. How do you like the duel nozzle?
Old May 16, 2007 | 05:16 PM
Boosted_Z28's Avatar
Looks good 2000GTP, I'd be interested in seeing your car in person sometime as we are only a few miles apart. How does the car run at the track?
Old May 16, 2007 | 05:51 PM
2000GTP's Avatar
To be truthful, I am not the biggest fan of the dual nozzle setup. As you can see, there is more plumbing involved and it is harder to keep a completely hidden and neat appearance.
Old May 16, 2007 | 05:57 PM
2000GTP's Avatar
I've yet to run it at the track. Maybe this season though, I plan on picking up some M/T radials here pretty soon.
Old May 16, 2007 | 07:17 PM
I have a set that I'm currently not using ...unfortunately, so you're welcome to "try" them out sometime.
Old Jun 6, 2007 | 03:34 AM
Steve in Seattle's Avatar
Wink
lol... I think it may be the plate that says NITROUS OUTLET that keeps it from being "completely hidden"... lol
Just don't pop your hood... although if a cop asks... errr... maybe hidden would be better
Old Jun 6, 2007 | 07:18 AM
2000GTP's Avatar
Yeah, maybe that was the wrong word to use. I think the point I was trying to get across was that by having the more plumbing to deal with, it was just a little harder to route things the way I wanted to. If a cop asks for me to pop the hood, I'll just say what everyone else says, "thats not mine, I don't know how that got there officer."
Old Jun 6, 2007 | 01:57 PM
91RSLT1's Avatar
What size shot are you running? If it is lets say a 150 then you jet each for a 75 shot correct? What are the advantages/disadvantages of a single vs. a dual nozzle set up. I am going to put my NX kit on soon and I kind of like the idea of dual nozzles.
Old Jun 6, 2007 | 03:59 PM
2000GTP's Avatar
I have it jetted at a 100 right now, I will only go up to a 150 on the stock shortblock. The advantages of the dual nozzle are the appearance aspect and it helps in supporting larger shots. A couple disadvantages are the extra plumbing involved and you can only adjust the shots in increments of 50.
Old Jul 28, 2007 | 09:18 PM
IROC-Z28_CAMARO's Avatar
I have a question about how you mounted your nozzle in your elbow.
It looks like you used the suppplied jam nuts did it seak on the elbow good since the rubber elbow kind of acts like a gasket and how is your hood clearence.
Old Jul 29, 2007 | 12:27 AM
2000GTP's Avatar
I have no sealiing issues, I did use a film of RTV as a sealer though. As for the hood clearance, it is tight, but it works. If I would have mounted the nozzles in a more upright position, then I probably would have had some clearance issues.
Old Jul 31, 2007 | 10:30 AM
WhyHelloOfficer's Avatar
That's a lot of stainless line everywhere! Kinda looks like spaghetti
Looks good though. Possibly in the future, you could look into hardlines and run them closer together from the solenoid to the nozzles for a slightly cleaner look. Are you running multiple stages?
Old Jul 31, 2007 | 02:29 PM
2000GTP's Avatar
What are "hardlines"? There is alot of stainless line because it is a dual nozzle setup, hence the comment I made in the above post of why I wasn't a big fan of it. I can't tuck the lines together because of length characteristics and placement, trust me I have tried. I am almost considering scrapping one of the nozzles and just turning it over to a single nozzle setup, but then I am going to have to fork over the money to get another elbow and redrill that one for a single nozzle. Then again I have been eyeing the direct port setup and I do have a spare LT1 manifold lying around that could be sent out...
