Filling bottle with remote opener attached
Old Apr 5, 2003 | 02:35 PM
JSK333's Avatar
How do you guys do this? I have an NX opener on an NX 15# bottle. Getting the opener on was a pain, so I can't imagine taking it off every time to have the bottle filled.
Is there an easy way to accomplish this that I am overlooking?
Thanks.
Old Apr 6, 2003 | 04:07 AM
a walker's Avatar
I would say take it off.
Old Apr 6, 2003 | 09:43 AM
gb95zconv's Avatar
Just take it off....youll get good at it after a few times....note the orintation of the opener on the bottle and the clamp on the opener and put it back the same way every time. I can put mine back on in a miniute or 2 now.
Old Apr 7, 2003 | 04:39 PM
JSK333's Avatar
Thanks for the input guys.
I may make a small harness that will double as a +/- for the fill station, so they can open & close it by switching the wires on a standard power 12V supply. Then I can plug it back into my existing setup.
Thanks again!
Old Apr 8, 2003 | 06:58 PM
gb95zconv's Avatar
If your intent on leaving it on.....you can just take the allan head screws out of the top and remove the motor and clutch assembly....then the billet piece can be turned with any small flat object that will fit .....or you could turn the clutch by hand(a bit messy with the grease)
Old Apr 8, 2003 | 11:05 PM
JSK333's Avatar
Greg, thanks a lot. I was going to ask and/or check myself whether the wires went into the part of the top that was removable.
That might be the easiest afterall! Thanks again!!
Old Apr 10, 2003 | 10:47 AM
95greendragon's Avatar
Well, as far as I know the opener will stay open it doesn't need electricity to keep it open. Open it before you disconnect it and it will stay open. I take mine off everytime its not too hard.
Old Apr 10, 2003 | 02:39 PM
gb95zconv's Avatar
Yes , but he might want to close it after its filled
Old Apr 10, 2003 | 02:40 PM
Um, then turn the manual valve off.
Old Apr 10, 2003 | 05:13 PM
gb95zconv's Avatar
If its the NX bottle opener you not going to be able to do that because the opener leaves no way to operate the valve manually....thus the question posed in this thread
Old Apr 10, 2003 | 10:51 PM
JSK333's Avatar
Yeah, thanks for the thoughts, though, guys.
I think I will probably go with removing the top portion where the wires connect, and manually open and close it each time.
You'd think NX would have thought of something when designing, with what seems like a basic design flaw. Yeah, you can remove it, but to me that cuts back from the whole point of ease-of-use of having the valve in the first place.
Oh well, such is life sometimes. Thanks again everyone.
Solomon
Old Apr 11, 2003 | 06:55 AM
gb95zconv's Avatar
One other point Solomon, thats kind of related and took me awhile to figure out. The easiest way to adjust the clutch is by hand with the top off. Tighten the clutch screw till it opens the valve when turned by hand( then go another 1/2 turn tighter)
calaban
May 18, 2020 06:43 PM
warmeck
Mar 24, 2015 10:52 PM
Jeff1904
Jan 3, 2015 12:00 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
