Does solenoid size affect jet sizing?
I am curious. Does the size of the solenoid make a difference in regard to the size of the hp shot with the same size jet? Example, - Super power shot with a 62 jet - is that equal HP as a Super Pro Shot with a 62 jet? Only other difference would be feed line to the solenoid. Solenoid to nozzle lines are the same, bottle pressure is the same. If it depends on how much nitrous is used, where is the general limit that they stop being equal?
Re: Does solenoid size affect jet sizing?
yes it will matter. On some applications not enough to worry about, on others send the system into a lean condition. The larger orifice solenoid will move more clean nitrous. What this means is less air bubbles in the nitrous stream. Cleaner nitrous more lbs. per hour for a given size of jet.
Ricky
Ricky
brothaslide
Jan 9, 2016 12:11 PM
350350
14
Aug 11, 2015 12:03 PM
Devinfoote87
Jul 30, 2015 09:54 AM
