Clutch Switch? Anyone also?
Old Jun 7, 2004 | 12:22 AM
red_rocket_z's Avatar
Guys have had "the gas" on my car for last 3yrs, and the guy who installed it put a clutch switch on it. Everytime you push the clutch in it kills the gas until you release the clutch. Said he did it for safety reasons. Is there anything better than this? It kills my track times.
Old Jun 7, 2004 | 03:48 AM
david97gsxr's Avatar
a window switch.
Old Jun 7, 2004 | 08:55 AM
MrDude_1's Avatar
you cant have the gas spraying when its in nutural. so your choices are to either lift throttle (taking it off the WOT switch)... running a window switch (cutting it off before you shift.. but if you drop into that RPM and have your foot to the floor, it will still spray)
or run a clutch switch, keep the motor at/near WOT and just have the juice spray only when the clutch is connected.
experiances of others around me tell me that the clutch switch is the fastest way to go... if you dont like it, you might as well swap to a auto.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
Jlo
Jul 29, 2015 03:52 PM
