cc503 and n2o?
cc503 and n2o?
how will my motor do, its a 355 stock crank, forged rods and pistons, heads have 2.02 intake valves and 1.56 exhaust valves, ported intake, cc503, 58mm tb, lt headers, ory and all the other bolt ons. i believe the compression is 10.75:1. how will hold up on spray and do i need anything else motor wise for the spray
Re: cc503 and n2o?
i had spray on my cc503. the car ran great! i blew a head gasket because i used a stock gasket. just make sure you get a good gasket, check the compression ratio and pull timing. make sure you dont have any detonation either and you should have a strong runner!!
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
