cc306 w/nitrous
Old May 28, 2008 | 09:53 AM
OPies57's Avatar
cc306 w/nitrous
my mods are listed in my sig i wanna spray my car so i can beat my friends mustang hes got 494hp/444tq with my mods i should be putting out around 350 360 hp and torque at the wheels. i was looking into doing a 150 shot. my main concern is the lsa on my cam is 112 will that hurt me at all? also was wondering about retarding my timing and if i should go dry or wet i thought i knew the difference but i dont think i do know after doing some research on this subject. i know of all the safety things to go with (rpm window switch, fuel pressure safety switch) i think because of his low tq numbers the nitrous should really help me i was gona run a 100 shot but some other guy said he got a racetronix fuel pump a mallory 685 ignition box a fuel pressure safety switch and colder plugs and was running a 150 shot on a stock motor i just wanted to make sure i could run a 150 on my motor with my mods.
Old May 28, 2008 | 11:12 AM
Ray@NitroDaves's Avatar
nope won't hurt you at all...it will actually help a little
I prefer wet kits on the LT1, as I do not like increasing the fuel pressure for fuel enrichment.
As long as you are running the correct heat range plug, a safe A/F ratio, and can retard the timing, you should be fine
Old May 28, 2008 | 07:00 PM
OPies57's Avatar
flipping awesome thanks brotha what heat range plugs should i go with and i read that the mallory 685 has a wire that goes into your nitrous kit and pulls timing accordingly that true?
Old May 28, 2008 | 07:19 PM
OPies57's Avatar
http://nitrousoutlet.com/catalog/pro...roduct_id=3204
does this kit come with a wide open throttle switch? and what fpss should i go with
Old May 28, 2008 | 08:33 PM
jakesz28's Avatar
What Ray said.
I hit the same cam with a little more then 150 and see held up fine.
Old May 28, 2008 | 09:51 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
That cam likes the spray... I picked up a little over a second and 12mph on NX's 150hp shot. 12.0's@115 to 10.9's@127
Old May 28, 2008 | 09:59 PM
OPies57's Avatar
wow thats ****ing insane what else is done to your car? im pretty excited
Old May 28, 2008 | 10:05 PM
home ported heads and a KTRE 12 bolt, all the other bolt ons - headers and all that. This was all 6 years ago though... Yeeesh! It sure doesn't seem that long ago
Old May 29, 2008 | 08:51 AM
NGK TR-6 (4177) or equivalent
that is correct
yes it comes with a WOT switch
you will need a high pressure FPSS w/a 4an manifold
Old May 29, 2008 | 10:09 AM
OPies57's Avatar
4an manifold? i have to plum my fuel rails?
Old May 29, 2008 | 10:27 AM
the fuel port on the factory fuel rails is 4an. Might just need a small 8" female line to connect the fuel rail to the FPSS. Don't know if you've got one already or not.
Old May 29, 2008 | 03:34 PM
the manifold will attach to the fuel rail test port....it will then give you two 1/8 NPT ports, one will be usd for the FPSS, the other is plugged unless you need it for another item. It also has a provision to attach the fuel feed line to one end of the manifold.
Old May 30, 2008 | 12:12 PM
OPies57's Avatar
nice sounds good anybody have an idea about power ratings i was thinking around 500hp/510tq with the kit. sound accurate?
Old May 30, 2008 | 01:14 PM
120rwhp on top of whatever you're making now.
Old Jun 4, 2008 | 08:35 AM
OPies57's Avatar
think my rear will handle this my friend said ill probly blow it right out of the car if so i think i might need to address that lol
