cc306 w/nitrous
cc306 w/nitrous
my mods are listed in my sig i wanna spray my car so i can beat my friends mustang hes got 494hp/444tq with my mods i should be putting out around 350 360 hp and torque at the wheels. i was looking into doing a 150 shot. my main concern is the lsa on my cam is 112 will that hurt me at all? also was wondering about retarding my timing and if i should go dry or wet i thought i knew the difference but i dont think i do know after doing some research on this subject. i know of all the safety things to go with (rpm window switch, fuel pressure safety switch) i think because of his low tq numbers the nitrous should really help me i was gona run a 100 shot but some other guy said he got a racetronix fuel pump a mallory 685 ignition box a fuel pressure safety switch and colder plugs and was running a 150 shot on a stock motor i just wanted to make sure i could run a 150 on my motor with my mods.
nope won't hurt you at all...it will actually help a little
I prefer wet kits on the LT1, as I do not like increasing the fuel pressure for fuel enrichment.
As long as you are running the correct heat range plug, a safe A/F ratio, and can retard the timing, you should be fine
http://nitrousoutlet.com/catalog/pro...roduct_id=3204
does this kit come with a wide open throttle switch? and what fpss should i go with
NGK TR-6 (4177) or equivalent
that is correct
yes it comes with a WOT switch
you will need a high pressure FPSS w/a 4an manifold
the manifold will attach to the fuel rail test port....it will then give you two 1/8 NPT ports, one will be usd for the FPSS, the other is plugged unless you need it for another item. It also has a provision to attach the fuel feed line to one end of the manifold.
