can miss adjustment of tps change n20
basically my 100 hit really good. now since i've been trying to fix some driveability problems it doesn't hit as hard. But i'm not sure if thats the problem. It Appears that its the tps but my car drives better now an don't want to change it back if i don't have to.
How is the TPS mis-adjusted? The TPS doesn't even need adjusted, as the PCM will automatically zero out the throttle angle.
------------------ Kurtis Tamez LT4-396.com 97 Z28 LT4-396 94 Firehawk LT1-396 Team NW F-Body |
It's readjusted because i loosened the bottom screw and pulled the bottom of the sensor slightly towards the front of the card in hopes to regain some lower rpm driveability. This will change where the computer thinks the throttle is so wide open and idle will have different voltages, so i assume it alters the air/fuel correct?
<font face="Verdana, Arial" size="2">Originally posted by KTamez: How is the TPS mis-adjusted? The TPS doesn't even need adjusted, as the PCM will automatically zero out the throttle angle. </font> What nitrous system? What type of WOT switch - mechanical or electronic? Hard to understand how TPS adjustment would affect the nitrous system, unless you have an electronic WOT switch. ------------------ Fred 94 Formula A3+1: 381/TH400+OD/N2O Advanced Tech Posting Guidelines Detailed Mod's List 11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year |
<font face="Verdana, Arial" size="2">Originally posted by Injuneer 94FormM6: Well..... not on an 89 GTA - they are adjustable, and need to be adjusted..... assumning that's what he is talking about..... he never bothered to tell us the detail </font> OTOH I'm not seeing where the TPS adjustment should be making any difference in the gain with the nitrous system... ASSuming (once again) its a wet system, everything is basically self contained. More details like Fred said. ------------------ Kurtis Tamez LT4-396.com 97 Z28 LT4-396 94 Firehawk LT1-396 Team NW F-Body |
sorry guys using an nx wet kit with a wot throttle swith.
i'm wondering if by changing the tps position and changing the air/fuel by moving the tps. Can this affect the hit or performance gain from n2o? |
