Can i run a mustang kit on my lt1?
i can get a mustang dry kit for cheap. can i run this on my 95z? im not going to run a throttle switch so thats no prob. everything else is the same is it not?
yes, i have the same mustang dry kit on my car and it works great
i bought iot used off a mustang for 150 bucks.a friend of mine has one just like it on his lt1 aswell. the only difference at all,is the lt1 kit comes with the fuel pump and its an upgrade with the mustang kit. you dont really need the pump its just added insurance. my friends car runs 175 shot with the stock fuel pump. and its been on the car for over a year with no problems. just hook the two vac. lines after the tee up to the fuel psi. reg. and the other to the intake. if your car is an auto. and you have some good d.o.t.s or slicks you should pick your e.t.s up by atleast two seconds in the 1/4.thats with about a 125 shot. later
any wet kit is almost universal. all you have to do is have the right fitting for the shreader valve and a fogger nozzle.oddly enough on that dry kit by nos inc. i saw one on a honda that was exactly the same. hope that helps you. later
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
