Blower pistons w/ nitrous, bad idea?
Old Oct 27, 2004 | 07:18 PM
Birdie2000's Avatar
355
8.4:1 compression
JE/SRP -24cc pistons
How much nitrous could these pistons handle? Would not be boosted while spraying. Am I severely limiting myself in the amount of nitrous usage by using blower pistons?
Old Oct 30, 2004 | 03:59 PM
Birdie2000's Avatar
Re: Blower pistons w/ nitrous, bad idea?
Anyone?
Old Oct 31, 2004 | 08:16 PM
12Second3rdgen's Avatar
Those are blower/nitrous pistons, the only thing you are missing out on is compression . What is the rest of your bottom end like? Should handle a 200+ shot no problem depending on rods, crank, ring gap, etc.
Old Oct 31, 2004 | 10:14 PM
texlurch's Avatar
Blower/nitrous pistons are pretty much the same, other than lower compression. They both have thicker top ring lands, and thicker decks to handle the higher loads. They should work fine, but I would run a slightly larger top gap if you want to spray on top of the blower.
The spray is actually a little easier on the piston, since you don't have the extra heat going in.
Old Nov 2, 2004 | 11:46 AM
andy katzelis's Avatar
I've made over 900 hp on blower pistons spraying and boosting (468 CID). Everything stated above is as I believe to be true/fact.
Old Nov 2, 2004 | 02:40 PM
94ltwonz28's Avatar
I have some scat 6in I-beam rods to go along with the pistons if you need them
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
