big line: inside or under car?
Old Nov 22, 2008 | 01:54 PM
sn8ke eatr's Avatar
where did you choose to run the main n2o line?
is it legal to run inside the cabin?
pros cons of each?
Old Nov 22, 2008 | 03:12 PM
You can install N2O components inside the passenger compartment. The only requirement it that the bottle has to have a blowdown, vented to the outside of the vehicle. Where you run the line isn't going to have "pros" and "cons".... its simple preference and aesthetics. I've always run mine outside the car. But they alays start out in the hatch area, which is considered to be part of the passenger compartment, unless you have a metal firewall in place of the hatch cover.
Old Nov 22, 2008 | 06:33 PM
slowride94z's Avatar
inside under the carpet, beside the drivers seat, down by the door trim, under the back seat into the hatch
through the big grommet for the wiring harness, i think
just if you drill a hole be sure to use a grommet
I dont like running wires with the line as it will chaff the wires
Old Nov 23, 2008 | 12:47 AM
sn8ke eatr's Avatar
so running the line in the cabin is cool with the nhra guys? that was my biggest concern
Old Nov 24, 2008 | 01:51 PM
Ray@NitroDaves's Avatar
yes it is legal to run the lines inside the car
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
