Best Setup
Old Jan 30, 2008 | 01:55 PM
  #16
86formula's Avatar
progressive shots are bad for the solenoids, just go with a straight 300 shot
Old Jan 30, 2008 | 02:00 PM
  #17
danhr's Avatar
ressurecting old threads is bad for the world.
and a "straight 300" shot is hard on the motor. I'd rather replace a solenoid every/every other season then replace a motor every other season.
Old Jan 30, 2008 | 02:19 PM
  #18
Ray@NitroDaves's Avatar
This will depend on the solenoids you are using, and how you are using the progressive.
My solenoids are over 5 years old and have countless passes on them. I have been using a progressive fro the last 2 years. My solenoids have never failed nor have they needed to be rebuilt.
My progressive is set to cycle the solenoids at 15 cycles per second. I typically ramp for 50-75% to 100% in .5-1.5 seconds. This will have the solenoids pulse 8-12 times per run.
As long as you are using a solenoid that has been designed for a progressive, and are not using the progressive for "horsepower" control, I see no reason the progressive is going to cause a solenoid failure. Now you should periodically check the solenoid for wear, but that should be done with or without a progressive.
Old Jan 30, 2008 | 09:42 PM
  #19
86formula's Avatar
and if the solenoid sticks open? youll be replacing the motor and the solenoid.
Old Jan 30, 2008 | 10:03 PM
  #20
danhr's Avatar
I believe ray covered that in the 4th section of his post
Old Jan 31, 2008 | 08:56 AM
  #21
Solenoids fail, in the closed position. The only way they "stick open" is from an outside influence. Either a foreign particle jamming it open, or a swolen plunger from using the wrong fuel with a given fuel solenoid.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
