August Nitrous Special!!dont Miss Out!!
Don’t Miss out on this one!!! This sale is good till the end of August or until supplies run out.
These Nitrous Express Main Line systems were purchased in bulk from NX and repackaged by Nitrous Outlet with all the parts needed to work properly with your application. The Main line systems you see advertised by other companies will not be the same as the systems posted in this special!!!
Group 1.
Nitrous Express Mainline single nozzle wet system.
This system comes with a 10lb bottle, 90 degree high flowing bottle valve, stainless quick release bottle brackets, 14ft -4 main feed line, 1ft -3 fuel and nitrous supply hoses, 200hp solenoids, aluminum solenoid mounts, Shark Nozzle, Nozzle adapter, Wide open throttle switch, Harness with relay, hardware, and jetting of 50-75-100-150 HP.
COST 399.99
Group 2.
Nitrous Express Mainline single nozzle dry system.
This system comes with a 10lb bottle, 90 degree high flowing bottle valve, stainless quick release bottle brackets, 14ft -4 main feed line, 1ft -3 nitrous supply hose, 200hp nitrous solenoid, aluminum solenoid mount, 90* Dry Nozzle, Nozzle adapter, Wide open throttle switch, Harness with relay, hardware, and jetting of 50-75-100-150 HP.
COST 375.00
Group 3.
Nitrous Express Main Line Two Valve Plate System.
This system comes with a 10lb bottle, 90 degree high flowing bottle valve, stainless quick release bottle brackets, 14ft -4 main feed line, 200hp solenoids, Billet 2 valve plate, Hard line supply for nitrous and fuel, Wide open throttle switch, Harness with relay, hardware, and jetting of 50-100-150 HP.
COST 399.99
!!!!!!!!!!FREE GIVE AWAY!!!!!!!!!!
As a way of us saying thank you to all the customers who support us we are going to give away two Nitrous Progressive controllers this month!!!
With any purchase you make from Nitrous Outlet during the month of August you will be entered in a drawing for a FREE Nitrous Outlet Progressive Controller.You must mention this add and tell the sales representive what web forum you are from so that he will add your name into the drawing.
The Nitrous Outlet Progressive Controller
*A compact controller that will fit into small spaces.
*40 amp capable draw.
*Easy to use and no computer is needed.
You can call in your order toll free at 1-866-648-7637
Thank you for your support!!!!!!
Dave
Group 1.
COST 399.99
Group 2.
COST 375.00
Group 3.
COST 399.99
Dave
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
ChrisFrez
Mar 22, 2015 09:12 AM
