383 LT1 stock heads with nitrous?
Old Jun 5, 2005 | 05:43 PM
djm_e22's Avatar
I am in the process of making a 383 Direct Port Nitrous LT1, my question is until I get the money to port out the heads and put new springs, retainers, valves and everything else that you could possibly be done to make the head stronger. Can I shoot a 150, maybe 200 shot of nitrous on the stock heads as long as I don't go past redline. For some reason I thought I read that the components in the head wore out or float only by going past redline. I will probably have to get some arp studs to hold the head down though, right? Thanks for any help.
Old Jun 5, 2005 | 09:35 PM
Eric G's Avatar
Re: 383 LT1 stock heads with nitrous?
Run as much blow as your bottom end will take. Or as much as you have the nuts for. Its just like NA, dont rev it too far and your fine.
Go ahead and get ARP studs, you'll be using them eventually anyway correct?
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
Brian-94TA
Jul 31, 2002 02:52 PM
