175 jets for NOS nozzle?
Old Dec 17, 2002 | 10:01 PM
ElkyRacer's Avatar
Anyone know the jet sizes? I saw the sizes for NX nozzle, but I need the sizes for a NOS fogger nozzle.
Thanks.
Kyle
Old Dec 17, 2002 | 10:53 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
76 for the nos
32 for the fuel
That nozzle will only flow 175 anyways
Old Dec 18, 2002 | 10:25 AM
snow2000SS's Avatar
That nozzle won't flow more than 150hp. The passage in the nozzle is only around .063-.065.
Old Dec 18, 2002 | 11:02 AM
ElkyRacer's Avatar
This isnt the standard fogger nozzle. This is the new annular nozzle if that helps. Thanks for the sizes guys. Guess for anything more Ill have to go with a 2nd stage.
Kyle
Old Dec 18, 2002 | 02:41 PM
snow2000SS's Avatar
Even the annular nozzle won't flow that much. The only one that will is the original 13700A nozzle. But it has a tendency to cause back pressure on the fuel side when you run bigger nitrous jets. Which means you need to run higher fuel pressures. So the best way to do it if you are going to use NOS nozzles is to go with 2 softplume nozzles. The annular nozzles are good nozzle but they can sometimes give tunning problems due to the fact that they can draw a vaccum on the fuel side causeing a rich condition at, high pressure this shouldn't be a major concern but the chance is still there.
Old Dec 18, 2002 | 10:17 PM
LTOne4Fun's Avatar
What the best nossle to use that candle handle a 175 dry shot?
Old Dec 19, 2002 | 05:01 PM
snow2000SS's Avatar
The 13500 dry nozzle would flow up to 200hp. And if you really want to get nutty you can run a 13503 which will do 350hp
Old Dec 23, 2002 | 02:39 PM
green85z's Avatar
Dude, you mean I can run up to 200hp and it won't lock up my injectors??? HEHEHE whats up shawn??
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Devinfoote87
Jul 30, 2015 09:54 AM
jbc3
Jul 28, 2015 12:24 PM
