150 shot on LT1?
150 shot on LT1?
well as of now ive been running a 100 shot wet, for about 3 weeks now and no problems!
would it hurt to jump it up to 150?
i have all safety stuff such as
digital window switch set at 3k-5.8k
bottle warmer
fpss
wot switch
and my mods listed below!!
would i be ok, or would i be looking for trouble?
bottle warmer
fpss
wot switch
Re: 150 shot on LT1?
won't be a problem at all thats all i like to use anyway,150 wet or 125 dry although i do not really like the dry systems.a set of autolite 103s will be good also, most of all hold on
...i just looked at your mods,on tire at HRP you should be running in the 12's on the motor so a 150 shot should get you deep in the 11's for sure or more!
i work on my buddies car as well as mt own(95&96z28s)
he has a 94 m6,clean car.
3.73 gears
autozone clutch
bmr lca'a and panhard
bbk 52mm
nitto 245/50/16 dr's
k&n cai
launching at 1200
zex 125 shot
no tune!he has run the fastest of 11.90 @113 w/2.00 60'
now the car has a tune from madZ,remember we are at a minimum of 2400' up here,HRP is 15'above sea level,i miss that track.....
3.73 gears
autozone clutch
bbk 52mm
k&n cai
launching at 1200
zex 125 shot
Originally Posted by crAzy95z28
compucar wet kit!
Originally Posted by 96m6lt1
yeah,you will be fine with that set up,as long as you have the nozzle and not that plate that goes in between the t-body and intake..
i have the TB plate
hmm,i really don't like the plate it was a great idea until you see how it flows into the intake it does not feed cyl.#1 and #2 as well as the rest i would change the plate to a NX nozzle and use their pills,roughly 65.00,just my observation when i used to work for the late JOHN STEWART @magnum plus nitrous off of beltway8 and lee rd,you will not do any damage to your motor with the set up you have now but more power with the parts you have now with the addition of the shark or pirannah nozzle will get you more hp to the rear....
to be honest i feel the tune up is most important,not even a burned plug has occured my 96 spun a bearing w/o the bottle everything else looks good,as far as the type of unit,the dry system at 1200psi hits harder than the wet at the same pressure that makes me believe the wet sysem is safer in ways.
