Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
Selling GM Crate 350 H.O. w/Accel Street Ram TPI & 700-R4 w/Hughes 3000 stall.
Old Jun 8, 2005 | 06:35 PM
IROC Z 350's Avatar
Arrow Selling GM Crate 350 H.O. w/Accel Street Ram TPI & 700-R4 w/Hughes 3000 stall.
Pics: 350TPI 350 350 350 350
(Phoenix Arizona area) This is a complete engine/intake/transmission package for sale (no part out) including:
*GM Crate H.O. 350, 4 bolt main, 9.1 compression, 212/222 @.050" Cam, 441 Iron Torqer Heads (standard port design), 1.94 valves, Rated @ 311hp and 369lbs of torque w/ dual plane and small 600cfm carb. Aprox 30K miles. Oil changes every 1500-2000 miles.
*Accel Street Ram 1000cfm TPI and ignition settup: Accel 1000cfm Throttle Body, Accel High Flow Runners, Bosch 24lb Injectors, GM factory Plennum and Base, GM Modified Mas Arflow Sensor, Accel: Cap, Rotor, 8.8mm wires, Adjustable Fuel Pressure Regulator and Gauge, and Super Coil. Arizona TPI Specialist TB plate.
*GM 700R-4 Automatic Transmission w/ Hughes 3000 stall lockup converter and shift kit. Throttle Valve cable included. Aprox 20K on rebuild by Western Transmission in Scottsdale. Calibrated for 3.42 gears.
*1985 GM CAMARO IROC Z28 ECM and complete wiring harness. Jet Stage II chip.
*Accessories shown in photos: Alternator, smog pump, starter, brackets, EGR, engine mounts, crank pulley, balancer, water pump and pulley, belts.
It's pretty darn near everything you need for installing this motor combination into almost any vehicle that fits a small block. Hotrod, 4x4 Truck, etc. Perfect for 3rd Generation Camaro/Firebird upgrade. Was run in an 85 IROC Z-28. Makes for a real easy swap. This engine just passed IM240 emmisions and runs great. If you're in the Phoenix Metro Arizona area and have an interest in this Complete Package let me know. It's viewable in the North Phoenix, PV area. Local pickup only.
Over $9000 invested. I am asking for $3300 for all of it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Feb 3, 2015 09:41 PM
Moshbmx1
Jan 20, 2015 03:27 PM
ModdedNerd
Dec 18, 2014 10:52 PM
