whos running duals?
I have duals. bullets. Id describe them as loud at slow speeds and very loud when getting on it, but descent at cruise speeds.
I had cheap super turbo's before and they were very quiet almost all the time. very stealthy. Im going to bring my old muff.s to M7 to test them back to back since its so easy to reinstall the old mufflers so I can know if there is any diff. in power from the mufflers. if not then Im going back to stealth mode.
chris
chris
Originally posted by PhantomTA
Harold,
what mufflers are you running? and how would you describe it the sound in different driving situations ?
if you can.. its hard as hell for me to describe sound..lol
Harold,
Dave, look up Oil Man WS6 (or Oil Man's WS6 can't remember) on LS1tech or LS1.com.
He's running true duals on his TA and I think has a couple of sound clips.
It got a little louder after the last cam change
But I have the Eldebrock RPM mufler on there. It is small & compact. Specs in Jegs.
I describe the sound as quiet rumble at idle & cruise, but loud when I hammer it. It is a nicer tone than with the bullets. Although, I'm sure the bullets have less restriction, so I'll be making mine adjustable, so I can switch muflers. I guess the sound would be close to a 2 chamber.
You're right, kinda hard to describe sound. I think it's quiet, because it is compared to the bullets that I had. Some might think it's loud. I know my landlord appreciates these muflers alot more than the bullets.
But I have the Eldebrock RPM mufler on there. It is small & compact. Specs in Jegs. I describe the sound as quiet rumble at idle & cruise, but loud when I hammer it. It is a nicer tone than with the bullets. Although, I'm sure the bullets have less restriction, so I'll be making mine adjustable, so I can switch muflers. I guess the sound would be close to a 2 chamber.
Jan 23, 2015 01:13 PM
