wanted to buy/borrow T56 output shaft
Location: windsor,ontario,canada Home of the fastest LS1 and LT1 6-speeds :D
Re: wanted to buy/borrow T56 output shaft
Originally posted by KGRESOCK
Needed for clutch install.
Does anyone have one I can borrow or buy?
TIA
Kevin
TIA
Kevin
You know that I have one. Just come over and get it. Or I'm working out at 23 mile, come and get it there, if that's closer.
if you need an alignment tool I will give you mine. If you are anywhere between muskegon and lansing, or close to it I could drop it off. It's company time, so I don't mind. Let me know tonite though.
I have a alignment tool but it's not deep enough for the street
twin.
Roman/Taner,
The Canadian connection.....I'll be coming to see you gentlemen
Thursday evening if thats convienent. Give you both a call.
Good day
Kevin
Save your time. They have them at autozone, thats where I got mine. It was like 3 bucks. The 8 and middlebelt one has a ton of them, in different sizes. Bring the clutch disc up there, find the one that matches, and you're ready to rock.
Much Thanks
The deed is done. Shifting is smooth, reverse engagement is same as stock.
Much thanks to DROYSTER for his time and muscle.
Taner/Roman thanks for the tips and wondertool.
480 miles to go for the break in, then off to the track
to punish it.
5k clutch dumps here I come.
to punish it.
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
awesome!! too bad it rained last night
Roman and i were heading over but oh well! next weekend is superfest
the 315 nitto's are ****ing awesome!!!!! and the ride is a bit more normal, then the et streets with 18#'s of air in the tires
importkiller94
01-17-2015 09:03 PM
