tune port fuel rails needed
friend crossing over too efi and the stelthram. It will work with the stockers tune port fuel rails just fine. Who has um lay'n around hes got cash in hand and a itchie trigger finger on the buy now button.
I have a set, including pressure regulator. They are from an '87 IROC, I believe. I also have the Earl's -AN fuel line adaptors for this fuel rail set so that it can be retrofitted into cars without OEM TPI fuel lines.
RedIROC, that's good info.
However, what injector rail does the StealthRam use?
I'd like to know for sure, purely out of curiosity.
Big Blue, if you want to try them out and give them back if they dont fit, that would be okay too. Better yet, bring over the manifold one of these days to my place and we'll test fit.
Got injectors?
Got injectors?
The Stealth Ram either has a set of fuel rails you can get with it or you can make your own with aluminum fuel rail stock. The Stocker TPI rails wont even fit over the very top of the "stacks" when you have the plenum off. They're too narrow, and would NEVER clear the bottom where the stacks flare out. I only cal them stacks because I dont know what they are called. I could take pictures in the next few days but I'd have to get over to my car. Also, I believe the injectors are in the wrong place on the stealth Ram compared to the TPI. The wiring is long enough to compensate though.
Check my sig for pictures, don't mind the rest of the pictures.
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
