Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
tranny help
Old Jan 2, 2004 | 07:06 PM
pskel350's Avatar
Unhappy tranny help
the tranny in my winter beater died, so i pulled it out this morning, rebuilt it, and put it back in. I bought an overhaul kit, new TC, and new pump. I put it together extremly carefully, checking the specs as i went. I thought i followed the manual perfectly.......well i guess i didnt
Reverse works perfect, but none of the forward gears work at all. Its a Ford c5 tranny, 3 spd auto. a guy at the shop said that i got something stuck in the valve body. does this sound likely? I did not take the valve body apart, since this is my first auto tranny rebuild, and i was intimidated by the valve body
i readjusted the intemediate band, but it made no difference. the tranny fluid level is right.
am i missing something obvious?
anyone have any ideas?
Old Jan 2, 2004 | 09:43 PM
Timberwolf's Avatar
in the front pump check to make sure the boost valve is in place. I don't have experience on the ford transmissions, but on the chevy there i a valve that goes up intot he pump fromt he button that is held in place by a circlip. If you have no forward motion at all, that means you are getting no hydraulic pressure ot the forward drums. The valve body pretty much programs your shifts, but I would still look at it secondarily for any valves not in place.
Make sure all your clutches and steels are in correctly (alternating), etc
Old Jan 3, 2004 | 12:41 AM
pskel350's Avatar
thanks
im going to take the valve body out in the morning, and see if it helps after it is cleaned. i dont want to pull the tranny again if i dont have to. the ford enginering sucks, and is a huge pita to pull the tranny
somehow i think i will end up pulling it out again though
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
