SE Mich
SE Mich
Hey guys....just curious...I have been looking at hopping up my 2001 WS6.I was thinking about setting the engine up to handle a supercharger. I then talked a facility called Detroit Speed Works (Warren, MI). They suggested to go the route of a turbo. I gues my question is if any of you guys have ever delt with this facility before? What facilities in the South East Michigan area have you guys delt with for f-bodies and what have you done? Your opinions and suggestions on where to go and what to do. I plan on building my car up in stages. My first trip to the garage I am planning on spending about $4,500. The only thing changed on the car so far is a Loud-mouth cat-back. I appreciate all your guys help.
Speedworks has many turbo f-bodies under their belt.
If you join Motown muscle ($25 a year) , you get a discount at Speedworks to.
not that i have heard anything bad about speedworks, but isn't the turbo kit they sell the turbo tech kit? from everything i have read about that kit/company's product from this board and others, alot of people have probs with fitament, etc.. do some research before laying down the big bucks. i hate it when you get something you have been waiting for and the end result just gets you
. good luck
. good luck
nj,
imo, I would go super rather than turbo just because the power is always there. Automotive Performance Engineering off of grosbeck hwy has a procharger kit that is basically a bolt on. No need to tap the oil pan. It produces 8lbs of boost I think. I will be putting this on my car as soon as I save up the money, the kit is 4800
Originally posted by Rockwound
nj,
nj,
I have seen what turbo cars can do, and i have seen what supercharged cars can do. I'll take a tubo please (if I could afford it)
hahahah... Car Pro? you talking about Eli over on Groesbeck? He is the reason I am asking about different shops in detroit
hahah... I f'ed up my '95 Z. Rockwound...that kit for $4800 your talking about.. I assume that is the p-1sc procharger? You have any idea what the charge for an install...and the other things is, running 8 psi on a stock LS1...shouldnt I have the pistons changed also? Have heard nothing but trouble when you go over 6 PSI on LS1's...I appreciate all your guys help
ROADRAGE......you have any idea ballpark, what I should be looking at for having a turbo system installed (parts, labor, dyno/tune)? Im guessing $6000-$7000...similar to a SC setup? Any other suggestions on what to do?
The cost should be right in S/C territory. The turbos go for around the same as a S/C kit, and install should be near the same.
I am no expert by any means, but i have 5 friends with turbo LS1's I can think of off the top of my head. Most were right around 500 hp after a decent tune, with a stock engine. You may want to post on motownmuscle.com , Almost all of them are mebers on that board and they could be a lot more help.
Z284ever
50
Aug 27, 2005 05:21 PM
Here goes another DSW vs. APE thread. Lets put it this way... ALL OF THE SHOPS IN THE METRO AREA are great, just don't go to CAR PRO MOTORSPORTS.
