Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Rearend Work - suggestions?
Old Oct 20, 2003 | 05:07 AM
Red5.7's Avatar
Does anyone know of a good shop in South-Eastern Michigan that does good rearend work? At the end of August I totally blew my posi out at the strip and I am going to just try to rebuild it and add a girdle for a little more strength. I am go I have the rearend dropped out and was thinking of just taking it to a shop when the time comes. (probably mid-march) I don't have the know-how or the tools to do it myself. I am also going to do a gear swap from 3.42s to 4.10s.
Anyone have a suggestion on a shop and a guestimation of what labor will cost to do the ring and pinion and differential install?
Old Oct 20, 2003 | 11:14 AM
91 Redd Sledd's Avatar
Call Andy Showerman 517-223-8944.ASE Master tech for a Chevy Dealership.He knows his stuff.Located in Fowlerville MI about 30-45 min from Detroit are. Does good work set up rears for at least 3 board members that I know of.All had great results.Very reasonable on labor rates also.Tell him James sent ya.!!!
He goes by Red roc wrench here on the board but he is busy so he does'nt get on here much anymore.
James
Old Oct 20, 2003 | 11:47 AM
1BAD86Z's Avatar
why pay shop prices?
i can rebuild your axle for alot less than a shop. i used to work at DTS and have been rebuilding axles at home for years. just ask around.
if interested call me at," scott" @ 586-801-8046.
Old Oct 20, 2003 | 01:10 PM
Andy works out of his home on the side.Did'nt mean to scare anyone into thinking he charges shop prices.
James
Old Oct 20, 2003 | 02:49 PM
Rippers_Evil_Twin's Avatar
Scott has done mine and he's great, Before you do anything give him a call.
Old Oct 20, 2003 | 03:09 PM
kandied91z's Avatar
i'd also have to second scott...he does alot of work for the guys around here and everyone has been happy with him.
Old Oct 20, 2003 | 03:36 PM
lsformula's Avatar
Scott just did my gears in my 96 Formula, Quick, reasonable and excellent work. I recommend him.
Old Oct 20, 2003 | 04:05 PM
CanIroc's Avatar
Scott did rearend work for me too. Replaced a posi unit for me. He does good work.
Bob
Old Oct 20, 2003 | 05:56 PM
CLOKWRK's Avatar
I'll vouch for Scott too! (No offense Andy) He did my 4:10's and they are super quiet!
Old Oct 20, 2003 | 07:16 PM
Dave89IROC's Avatar
yeah, scott put 3.73's in my IROC THIS PAST WINTER, GREAT,M NO NOISE OR LEAKS, HE DOES GREAT WORK
Old Oct 21, 2003 | 09:46 AM
1BAD86Z's Avatar
gears
Well i have had my hands in many rear ends, can i put my hands into yours?
Old Oct 21, 2003 | 11:03 AM
Red5.7's Avatar
Re: gears
Sent you a PM yesterday
Old Oct 21, 2003 | 04:05 PM
redroc wrench's Avatar
Red5.7,
I'd be happy to help you out with your rear end. If you took it out and brought it to me that would be very easy. Sounds like extra work for you though. It's up to you. You can call me at the above number James gave you. Whenever. If you have Scott do it then that is fine, he sounds like he has a lot of experience also. Which is what you want on something like a read end job. Good luck!
Andy
Old Oct 21, 2003 | 04:39 PM
I tried to stick up for ya Drew. Where was Harold and all the other guys when you need them?? Andy is really good but it sounds like Scott is closer to you.I have heard that Scott is very good also and knows his stuff. I had to try to sell Andy though.nothing personal. Sounds like no matter what way you go,your rear will be set up properly.just as long as Scott does'nt get his hands to far up there.Sounds like that would hurt!!J/K
James
Old Oct 21, 2003 | 11:09 PM
1BAD86Z's Avatar
pm's
For some odd reason i haven't been able to recieve PM's. does anyone have any idea what i might be doing wrong?
p.s. call my cell red5.7
