PRICE LOWERED! 11 second Z...down to 7500 OBO!!
PRICE LOWERED!! 11 second 94Z, $7500 OBO!
MUST SELL!! Bank says no vette til this car is gone (wife agrees)! And I already won the vette auction on eBay!
1994 Camaro Z28 hard top. Polo Green
Just rebuilt A4 trans with Transgo shift kit and corvette servo, B&M Trick shift fluid is the only thing used since rebuild.
Yank 2400 converter, 5000 miles in a new trans, flushed, and then 100 miles in mine.
Energy suspension trans mount.
Fresh brakes.
TWO sets of wheels and tires: Pro stars with skinnies up front and ET streets in the back, and a set of salad shooters with goodyear GSC tires.
No airbags.
No heat or AC. Lots of room in the engine compartment now and the car only weighs 3200lbs with full interior!
99 Pewter gray interior
3.73 gears swimming in Mobil 1 synthetic lube
BMR tubular lower control arms.
Metco driveshaft loop
high speed balanced drive shaft with new U joints
motor has had top half rebuilt 28k miles ago including opti
Mobil 1 synthetic oil
Trick flow polished aluminum elbow
Lingenfelter CAI with K&N
Jet Hot long tubes with sterling finish
True duals with dynomax bullets
GMPP 1.6 roller rockers
MSD 6AL
MSD window switch
Adjustable low RPM pill (for the window switch)
Several pills (fits BOTH ignition and window switch)
MSD blaster coil
SLP Line lock
Compucar 90-150hp adjustable wet nitrous kit.
Bag full of jets to fine tune for more or less power
Bottle opening solenoid, purge kit, customs switch panel
WOT switch
Fuel pressure safety switch
IHRA/NHRA legal blow done tube with safety valve
bottle pressure gauge
Custom switch/LED panel
Jas racing seat with mounting rails and slider kit included
CompCams XE230/236 cam included but not installed
Brand new B&M Ratcheting megashifter still in box
Weighs only 3200 with full interior and half a tank of gas!
Has run 11.7 @ 119mph with 1.702 60'
Will run 11.5 easily with more tuning (I'll include the connection cable for tuning too)
Are you ready for this?
First $7500 and it goes. I will pay half shipping costs too to the lower 48!
I have lots of pictures if you want to see them.
AIM: timberwolfZ28
Fresh brakes.
No airbags.
MSD 6AL
MSD window switch
MSD blaster coil
SLP Line lock
WOT switch
AIM: timberwolfZ28
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
Jan 23, 2015 01:13 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 1, 2014 08:08 AM
