Power driver's seat dead
no help from the "LS1" board, so I thought I'd try my local group.
After a water leak, and running the driver's seat forward to dry out, the seat won't move. Of course I have checked and WD-40'd the only electrical connecter that I could find. Now with the seat run fully forward, I can't even get into the car, let alone reach the front mounting bolts to remove the seat to fully check out the problem. The 6-8 wire connector was dry and clean, but I checked anyway. Is there another connector that I can't seem to find? Can I hot wire the connector to at least power the seat back to remove the front bolts. Thanks to all for any help.
Edit: I have checked the fuse, the defroster works and upon further investigation, the connector coming out of the carpet under the seat does NOT have 12VDC at any of the connectors. Anyne know of any other connectors in the circuit?
Jan 23, 2015 01:13 PM
