Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
ok, the cable is assembled...first scan is here
Old May 20, 2003 | 04:59 PM
Timberwolf's Avatar
Just an idle scan usind datamaster...
Lterms hover around 117...Sterms around 123-127
I need to find a place to do a logged run...
anyway...here's a start (right-click and save as...):
idlescan
Old May 20, 2003 | 08:35 PM
Grover's Avatar
Okay, your idle scan is showing that you have a problem with the Left O2 sensor. Set up the graph at the bottom to show the left and right O2 and you will see the right one going crazy and the left pretty lazy. At closed loop it should be jumping up and down continuously like the right one.
Old May 20, 2003 | 09:10 PM
Timberwolf's Avatar
I got a WOT scan too. IF you follow the rom graph compared to the mph reading, you will see I had wheel spin through 1st and partially second. the mph reading was around 70 and then slid all the way down to under 40 as the tires grabbed the pavement. At that point the RPM was around 2700 and in second...so it was a bit out of the powerband. According to my calculations it took over 14.5 seconds to get to 90mph
Anyway, see what you think. notice I got NO knock retard at all. max advance was around 37 degrees
WOT scan
Old May 20, 2003 | 09:26 PM
Grover's Avatar
The WOT graph looks good. The only thing I see that I think you should check is the left O2. Either you have an exhaust leak or a bad O2. I think it is more a bad O2 than anything based on the idle scan. Your long term BLM's look good locked at 128 for the whole WOT run.
Old May 20, 2003 | 09:53 PM
Timberwolf's Avatar
well, I am pretty sure I have a leak on the pass side but not the drivers side
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
KYWes
Sep 26, 2015 08:49 AM
tommalcolm
Sep 11, 2015 03:39 PM
