Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Odds and Ends 95' Z28 parts FS
Old Apr 28, 2009 | 09:49 PM
squinn's Avatar
VFN lightweight carbon-fiber, this hood fit 93 -97 Camaro, this is a stock looking flat hood. It is of bolt on type, weight is ONLY 12 LBS!! 33LBS LIGHTER THEN STOCK!! Hood is unpainted and has only been fitted. This hood new sells for $700 plus fright shipping. hood has one small chip in it. I'm looking for $300
Competition Transmission 8" Converter, 5500 stall $350
4th gen motor plate SBC $75
MSD RPM Modules 7000-7800 rpm MSD # 8747 $20
MSD RPM Modules 4000-4800 rpm MSD # 8744 $20
LT1 radiator, a little beat up $20
Plastic radiator support $10
Rubber shifter boot from 6 speed car $5
Z28 front sway bar $10
Z28 rear sway bar $10
Stock panhard bar $5
Upper panhard bar support $5
Front z28 springs $20
LT1 air pump $10
Tire jack $5
A/C compressor $20
Related a/c component $10
Windshield washer tank $5
Lt1 rear main seal adapter $5
Lt1 water cross over tube with bolts $5
Lt1 oil pump drive $5
HD oil pump drive shaft $5
Old Apr 29, 2009 | 06:09 AM
detroit1994z28's Avatar
Re:
Sent you a pm on the front sway bar - mike
Old May 5, 2009 | 08:26 PM
Z284thgen's Avatar
steve email sent to you
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
