Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
need help ????
Old Mar 12, 2004 | 01:03 PM
2MUCHZ's Avatar
need help ????
well i got the 355 in i have a little problem i think it has to do with tuning just want to confirm....The car starts fine and runs good until it gets warmed up then the idle bounces around and stalls it will start right back up if i give it a little gas....The cam is XE 224/230 112 lsa, 1.6 RR, ported and polished heads with bigger valves, deleted AC and air pump (smog) thats about it...Any help would be appreciated...Also if it just is a tune do any of you guys have tunercat or the capability to do this.....thanks alot
Old Mar 12, 2004 | 01:05 PM
IROC5.7TPI's Avatar
Sounds like tuning issues to me..
Old Mar 12, 2004 | 01:53 PM
dreamer1q's Avatar
Let me guess, you put a bigger TB on it? If so I know a little fix for it, but you still want to get it tuned....
Old Mar 12, 2004 | 07:06 PM
TrouserSnake's Avatar
No Tuner Cat but how much should I save up for your block?
Old Mar 13, 2004 | 12:43 AM
2MUCHZ's Avatar
Any body here know how to tune this thing or do you guys know somebody who does good work....Trouser its yours for 200.00 let me know thanks
Old Mar 13, 2004 | 12:47 AM
triumph's Avatar
Charlie or Strokinpolo has a # for a local guy that can do it. Steven
Old Mar 13, 2004 | 07:22 AM
dreamer1q's Avatar
Greg Banish at Livernois does mine, and I am very happy. My suggestion would be to get ahold of him and get some dyno/tuning time.
Q
Old Mar 13, 2004 | 07:46 AM
Timberwolf's Avatar
probably need to open up the air bleed hole in the throttle body a little bit.
Do you have any lights on? Sounds like it could be a an o2 sensor or map sensor issue as well since you don't have any problems until the car goes into closed loop.
