need help ????
need help ????
well i got the 355 in i have a little problem i think it has to do with tuning just want to confirm....The car starts fine and runs good until it gets warmed up then the idle bounces around and stalls it will start right back up if i give it a little gas....The cam is XE 224/230 112 lsa, 1.6 RR, ported and polished heads with bigger valves, deleted AC and air pump (smog) thats about it...Any help would be appreciated...Also if it just is a tune do any of you guys have tunercat or the capability to do this.....thanks alot
probably need to open up the air bleed hole in the throttle body a little bit.
Do you have any lights on? Sounds like it could be a an o2 sensor or map sensor issue as well since you don't have any problems until the car goes into closed loop.
