Michigan Guys/Gals, Workout Station
This could make a great gift for the Holiday SEASON!!
The Weider 8630 Weight Home Gym System. I paid just over 500 dollars for this entire gym setup. I must sell this equipment as soon as possible. As you can see in the pictures, the equipment is flawless. Pratically BRAND NEW, you must see to believe.
The system is already disassembled and ready to move ASAP. However, need not worry, reassembly is easy, as I left most of the major parts together so a pick up truck is all that is needed to get this system to your home, and about 15 minutes of screwing in some nuts and bolts.
This system is perfect for doing multiple exercises for all muscle groups.
The Weider 8630 allows you to workout at home at your convenience instead of on a gym's timetable.
It Features:
Frame Tubing: 2.0" Square
Upholstery: Standard
Foam:2.0" Standard Grade
Cable:7 x 19 Nylon Coated
Pulleys:3 1/2"
Weight Type:Vinyl
Stack: Dual
Total Plate Weight: 212lbs
Maximum Resistance: 410lbs
Exercise Options: Bench Press; Butterfly; High Pulley - Lat Bar; Leg Extension; Low Pulley; Leg Press
Weight: 275lbs
View picutres at
http://www.villagephotos.com/pubbrow...ame=Weight+Set
If you have any questions contact me at smurfman8@hotmail.com
Asking price is $225-250. MUST SELL ASAP.
We can even arrange a delivery if needed!!
It Features:
Pulleys:3 1/2"
Weight Type:Vinyl
Stack: Dual
Weight: 275lbs
View picutres at
Re: Michigan Guys/Gals, Workout Station
Its not that big disassembled. Its longer than it is wider. I brought it up from my basement with no problem. If worse came to worst you could always unbolt a few more pieces. Hope this helps, let me know.
Thanks,
Kevin
Thanks,
Kevin
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
firstgen
Sep 14, 2002 12:55 AM
