Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
LS1 edit question
Old Nov 10, 2002 | 09:05 AM
Firehawk#69's Avatar
LS1 edit question
Had my car programmed with ls1 edit, from one of our local performance shops. My queston is; They removed the codes for the secondary O2 sensor since I had an offroad y installed and decided not to get O2 simms, but the codes appear when I use autotap eventhouth the SES light never comes on. Is this correct, or should the codes never even show on atap?
Marco
Old Nov 12, 2002 | 10:18 AM
turbolx's Avatar
Lightbulb
If done correctly, the code should never appear on ATAP either. LS1edit give you the ability to simply shut off the MIL indication for that code (although it would still be stored) _OR_ completely disable the test that generates the code (which would prevent it from ever seeing the failure). It's usually not a big deal as long as you know that nothing's really wrong when you see that code with ATAP, but we usually completely disable the test for "off road applications" here.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
ChrisFrez
Nov 23, 2014 10:33 AM
Bando
Aug 2, 2002 02:18 PM
