looking for a torque converter and ? on bolts replacement
looking for a torque converter for a 99 4l60-e. stock or mild, let me know what you have. i need something that doesn't have to be rebuilt.
anyone recommend a good place for bolt and screw replacement on the east side? they don't make rebuild kits for irocs and i have alot of bolts i'm looking to replace.
also, anyone know where i can find the proper dimensions for the bolts that hold the 4l6o-e to the engine. the setup i bought didn't come with them.
thanks.
thanks.
I have one out of my 01. It had maybe 2000 miles on it when I yanked it & put in a Vig 3200. You can have it.. I took the plug of the Vig and put it over the hole on the stock one, it should be fine. I'll look for it when I get home, to be sure it's still around.
I doubt I'll ever have a need for it..
I was up in the attic (in Lansing) and found that I still have my stock stall from my '02 Z28. Has probably 40K miles on it. Worked great for a stocker. But, I wanted more slip and went to a MW converter.
Make me an offer if you're still looking for one.
squarehead
Nov 21, 2014 08:02 PM
