Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Looking for a Non vented Opti
Old Mar 5, 2004 | 05:53 PM
spoogen622's Avatar
Im not 100% sure that my problem is the opti so Im looking for one that works with not alot of miles on it
thanks
Old Mar 5, 2004 | 06:12 PM
94_Z28_ragtop's Avatar
I have the original one from my car w/ 60k miles on it. It worked fine when it was on the car. I replaced with a vented one when I did heads and cam. But... you can get a brand new one with warranty from Auto Zone for $150.
Old Mar 5, 2004 | 07:27 PM
triumph's Avatar
Russ,
Did you try that sensor i suggested? Or are you just getting around to messing with it again? Steven
Old Mar 5, 2004 | 08:01 PM
spoogen622's Avatar
94 how much do you want for the one with 60k on it?
steve , I went to change the injectors and before I started the car wouldnt fire. it would crank but no fire. checked the fuel preasure with no luck. So I thought with 101k the opti is bad
(it does have the original on there now) Im wishing I had air tools ,the hub bolts are a bitch to get off.
Old Mar 5, 2004 | 08:27 PM
triumph's Avatar
What do you mean no luck checkin the fuel pressure? None @ all? Does it still have spark? A bad MAP sensor on a 93 speed density system controlls timming,spark and fuel. I would start with the easy stuff before rippin it all apart. If you need my help i have the time now. Steven
Old Mar 5, 2004 | 08:30 PM
triumph's Avatar
Too bad you cant get it here i have the AIR tools if it in indeed is the OPTI.
Old Mar 6, 2004 | 10:20 AM
How about $75?
Old Mar 6, 2004 | 10:29 AM
spoogen622's Avatar
94 ragtop you have a pm
Old Mar 6, 2004 | 01:51 PM
I sent you an email.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
