Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
HELP!! rotors are rusted on!!
Old Sep 13, 2004 | 07:28 AM
JCM_1970's Avatar
does anybody have any suggestions on how to get these things off on the front I have tried heat, heavy brass hammer, wd40 and a couple of c clamps and a piece of steel across the center hub I have been trying for hours if anybody could give me some insight (some bolts I didnt see on the inside ) it would be appreciated!! it is a 98 camaro if that will help I have paper work from the previous owner saying that they were changed 2 years ago but with the amount of rust back there I am having a hard time believing that!!
Thanks! in advance everybody!!
Jack
Old Sep 13, 2004 | 07:53 AM
OneSickSix's Avatar
Re: HELP!! rotors are rusted on!!
....Brake cleaner? :P
Old Sep 13, 2004 | 07:59 AM
MrDude_1's Avatar
smack it with a hammer back ON.... you probly have it cocked sideways a lil bit.
it just slips on and off.. but its a tight fit. if you get it crooked, it becomes jammed and wont come off.
the rust is because its bare metal exposed to the elements. nothing unusual. on the trucks that drive on the beach on the outer banks of NC, ive seen the rotors rust in half...the vains in the middle rust apart... but it takes years and years of driving in salt water for that to happen. no worries.
Old Sep 13, 2004 | 08:15 AM
JCM_1970's Avatar
thanks guys
tried both of those ideas but they didnt work. whole can of brake cleaner and trying to push it back on it just didnt budge either way!! keep em coming!!!
Old Sep 13, 2004 | 08:36 AM
firehawkformula's Avatar
undo the tierod end so the spindle can turn and take a heavy sledge hammer and hit the rotor from behind, I just replaced the rotors on my 95 firebird and had to do this same thing. I ended up placing the tierod ends too
Old Sep 13, 2004 | 09:00 AM
valu8or1's Avatar
When I replaced my rotors on the Expedition I was forced to to cut slots in the rotors with a reciprocating saw and split them in half with a chisel and hammer. I tried beating the first one off for over an hour and it did not work. Just make sure you do not cut into the brake mount or the steering knuckle. The second one came off in 10 minutes.
Old Sep 13, 2004 | 09:07 AM
Timberwolf's Avatar
PB Blaster is your friend
Old Sep 13, 2004 | 06:24 PM
OneBad98Z's Avatar
I'v had this problem in the past. I like to take emery cloth, or medium sandpaper to the hub to remove the rust and and spray the hell outta it with wd-40 pb balster, etc. Give it a few good raps with a plastic dead blow hammer, hittin from the outside in on the brake pad surface like also stated be sure to see if you cocking the rotor on the hub. Just be sure that once you do get it off you clean the rust off good and you should have the problem in the future, some people like to grease the back sides of the rotors.
Later,
Greg
Old Sep 13, 2004 | 09:26 PM
IrocSS85's Avatar
yeah, the only way is with a BFH. hit from the backside towards the outside. hit it once and rotate the rotor around some, hit again, etc. have you tried pb blaster on the backside of the rotor, between the hub and rotor? thats where its rusted together. a brass hammer more then likely isnt enough. you need a minisledge or a deadblow hammer (plastic hammer filled with 2 lbs of sand), and you really need to whack it good sometimes. but it will come off.
chris
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
BMX Dad
Aug 15, 2015 01:15 PM
Anon
Jul 23, 2015 12:18 PM
