Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Headers make car run slower???
Old Jul 3, 2004 | 04:01 PM
mavricki18's Avatar
my previous best was a 12.87 @ 110 I picked my self up a set of FLP LTs bring the car to the track and i run a 12.9 and i couldent get my trap higher that 109. Could this be because of the conditions out side? I dident get the car tuned to get rid of the SES light for the EGR could that have anything to do with it?
thanks, Dane
Old Jul 6, 2004 | 12:09 AM
mavricki18's Avatar
so basicly i lost power?
Old Jul 6, 2004 | 09:14 AM
WhiteHawk's Avatar
You probably did lose power without tuning. It usually goes like this: Your car now needs more fuel for part throttle driving, so your ECM is adding most of the time from it's base settings. The problem is that when you go to ful throttle, it adds the same amount of fuel. If you scan it, it will tell you for sure, but that is pretty common with a header install.
If you don't want to spring for tuning, you can probably straighten it out with a MAF translator, but you still need a scan tool. Just keep leaning it out at part throttle until the Long Term Fuel Trims (LTFT's) go negative.
-Geoff
Old Jul 6, 2004 | 09:42 AM
cASe SenSiTive's Avatar
Exposed Member
It's possible that tuning is an issue. But the track conditions/weather could play a part as well.
Old Jul 6, 2004 | 10:04 AM
IROC5.7TPI's Avatar
Track conditions can play a big part... What were your 60's like on the before and after passes? Its possible your just losing traction now that you're (hopefully) making more power.
Best thing to do is get it on a wideband O2 and see whats up.
Old Jul 6, 2004 | 10:30 AM
RedIrocZ-28's Avatar
Your SES light is on which means you are running in open loop. I don't know about your car but in 3rd gens, we go open loop at WOT so we have to change our PE vs. RPM, PE vs. Coolant temp, PE vs. LV8 (load) etc etc etc. Your headers are pulling your exhaust gasses out better and actually may be messing with your O2 readings (falsifying them). So.... your car is trying to compensate for a phantom problem (thinks its running lean) that does not exist. So in this case, its dumping more fuel in, and running up your effective Air Fuel Ratio to probably somewhere in the 12.0 range. Most motors like it in the 12.7 range. I can tell you that even on a fucxked up motor I was able to pull 20 RWTQ and 10rwhp by tuning the fuel and spark curve at WOT.
You need a tune to get rid of the codes. It goes into failsoft mode with an SES light on and you're running at less than optimum.
Old Jul 6, 2004 | 01:22 PM
DJ_951's Avatar
I have read some cars are more secitive to LT than others. Did you put sims on the rear O2 sensors. That also trips the SES light.
Old Jul 6, 2004 | 07:13 PM
mavricki18's Avatar
thanks for all the help guys
i put 0s sims on but the SES light is on from the EGR.
if i get the the EGR tuned out will it fix the problem or will i have to get my car dyno tuned.
If so how much will it run me to get a tune job around the are and who does them? ( Livernois, APE???)
Old Jul 7, 2004 | 10:32 PM
mavricki18's Avatar
The 60ft times were the same oll crappy 2.1xx as they were before the header install. how much would a tune run me (ball park)???
thanks for the help, Dane
Old Jul 8, 2004 | 12:11 PM
Call up Joe at Livernois. He'll probably be able to hook you up with a nice dyno tune.
Rob, did they make 30 more peak torque at a sacrifice of area under the curve style torque just to get some quick "look we got you more power" numbers? If so, your buddy needs to throw a big fat cam in there and really start breaking the sound barrier.
ro2207
Dec 4, 2014 06:18 PM
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
