Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Has anyone ever repaired a rusted QTR panel.
Old Sep 4, 2004 | 05:31 PM
POSSESSEDZ's Avatar
I just bought a 89 camaro rs when stripping it down . I have a good size rust hole in the lower rh qtr. behind the gfx. I know i need too cut out the rust and fab sheet metal to patch. but what size material thickness should i get. and has any one done this before if so how much would you charge to do it. i live in ferndale. Thanks.
Old Sep 7, 2004 | 11:51 AM
WhiteHawk's Avatar
Re: Has anyone ever repaired a rusted QTR panel.
Got to shermanparts.com and order up a new quarter panel and have it welded in. Much easier than trying to fab up a patch. I put a floorpan from them in my old GN, and it fit like OEM.
-Geoff
Old Sep 7, 2004 | 03:35 PM
IROC5.7TPI's Avatar
Its not a big deal if you have the right tools. Get the same thickness metal, cut out the old, weld in the new. weld/grind/bondo/prime/paint = good as new if you know what you're doing. Getting a whole new 1/4 is senseless if theres just a small hole.
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
Formula Steve
Sep 19, 2015 08:48 PM
