Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Grover
Old Apr 6, 2003 | 07:53 PM
dreamer1q's Avatar
Grover
What did you hot wire this MSD box into? I figure since our locations and cars are the same, I should use the same hot switch. Since you went and let me all that pretty wire, it should be a breeze.
Q
Old Apr 6, 2003 | 08:23 PM
Grover's Avatar
The large red and black wires with the eye ends on them I ran across in front of the radiator to the + and - junction boxes next to the battery. The other wires get hooked into the coil, if you got the harness then you won't have to cut any of the wires. I believe that is it, as far as the location I had it mounted to the front of the radiator support where the CAI goes through on most cars as shown here
Let me know if you need more info.
Old Apr 6, 2003 | 09:10 PM
dreamer1q's Avatar
Thats exactly what I needed. I am also mounting in that spot, and I have the harness on order. This should be a breeze.
Thanks!!!
Q
1fast Firechicken
Apr 21, 2004 04:04 AM
