Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
cleaning undercarraige
Old Feb 18, 2005 | 11:51 AM
limige's Avatar
how do you guys cleanup underneath the car when you building it?
should i just powerwash it or take to in to have it sandblasted and painted?
right now the rear is out, tank is out, pulled all the gas and brake lines, engine and trans is out so it seems like the best time to do it.
thanks,
mike
Old Feb 18, 2005 | 02:20 PM
IROC5.7TPI's Avatar
Re: cleaning undercarraige
If it doesn't need to be painted, just cleaned I use wheel cleaner. Its strong enough to remove just about anything under there. If you can, spray it on and let it soak for a few minutes then get a scrub brush and scrub the thing down. Hose it off and it should be good as new.
Old Feb 18, 2005 | 08:14 PM
IrocSS85's Avatar
simple green, plastic bristle scrup brush's, and a hose is all thats needed. dont even think of sandblasting it.
chris
Old Feb 19, 2005 | 05:20 AM
limige's Avatar
alright, i borrow my buddies powerwasher and some orange soap from work, that outta do the trick!
Old Feb 19, 2005 | 06:07 AM
IROC5.7TPI's Avatar
Simple green is the best for mild stains, buit wheel cleaner is cheap and takes off everything
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
