Chag Beebe*** Driveshaft info inside.
There is a little shop in Concord MI that can make you a driveshaft.
It's called A&I Balancing... (517)524-8655 13300, M-60 Concord.
You might check with them. They have done work for me in the past and are very knowledgable. Good Luck!
HInk
HInk
... After blowing your ALUMINUM shaft to smitherines, in front of hundreds of people, I thought you just might want to change your name, Gropper!
HInk (Real Smart Azz Today)
Check here for other people that use ALUMINUM driveshafts for drag racing. I think I got the lower version instead of the Metal Matrix Composite Aluminum version.
I CANNOT FIND THE WIRE TO TIE MY 4 BRAKES TO THE SWITCH.
DO I LOOK UNDER THE DASH? I found a relay under there but when it isn't plugged in the car won't start. Am I looking for something that will only give a 12 volt signal if the brake pedal is depresses??
HELP I am a STUPID SOB
HInk
HInk
CARiD
Sep 7, 2015 08:21 AM
