Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Broken Block Mount bolt.
Old May 9, 2006 | 12:46 PM
Ekof96Z28's Avatar
Hey guys, Passenger side. The top right bolt that bolts the mount to the block is broken. Just picked up the engine from a salvage yard. Noticed there is a minor seperation to the right and left of the bolt as well in that little bung that it screws into.
Is this something to be concerned about? Or should I just drill the bitch out and put a new one in. I tried turning it out w/ vice grips but it just tore the threads off of what was sticking out.
Old May 9, 2006 | 02:15 PM
dreamer1q's Avatar
Re: Broken Block Mount bolt.
Drill, ez out, replace. Easy as PIE
Old May 9, 2006 | 02:16 PM
JakeRobb's Avatar
Super Moderator
Title says: Broken Block Mount bolt
I read: Brokeback Mountain bolt
I guess we had one too many threads about that movie...
Old May 9, 2006 | 09:17 PM
IrocSS85's Avatar
try heating the block around the broken bolt with a propane torch. if that doesnt work, the only way to get it out is with an easy out. you gotta drill out the middle of the bolt and tap this tool in and when you turn it backwards it will bite in deeper and should turn out the bolt. key is to use the right size drill bit for the easy out your using (it usually says right on the bit what size to use) and heat the block around the bolt. and make SURE you drill in the center just in case you need to drill out the whole bolt.
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
